Shaking 04 v6 1500 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 3.7L PowerTech V6 Specific Topics
Old 05-14-2019, 05:39 PM
Dallaslebeau210 Dallaslebeau210 is offline
Vehicle: 2003 Dodge Ram 1500 quad cab
Color: Brownish
Dallaslebeau210 is on a distinguished road
Default Shaking 04 v6 1500
So my 04 ram 1500 shakes really bad when accelerating so I thought u joints. I checked u joints and they seem fine . I also noticed it has a bad shake when in park. This happened after driving thru some really deep water after a storm one day. Truck also smells rich. Any info would be fantastic.
Old 05-14-2019, 06:03 PM
Beagleman's Avatar
Beagleman Beagleman is offline
Vehicle: 2019 Ram 1500 Classic 4x4
Trim Level: Quad Cab, Tradesman
Rep:14
Beagleman is on a distinguished road
What shape are your spark plugs in...Also have you checked motor mounts for looseness or cracked....
USAF RET.
Old 05-18-2019, 05:28 PM
Color: Brownish
Ok so before I didn't know how to check for.codes. I checked codes and 0304 cylinder 4 misfire and 0052 02 sensor on bank 2. Which one would be the best to do first as I'm on limited budget atm.
Old 05-19-2019, 10:38 AM
Engine: 2002-2012 226ci (3.7L) Magnum/PowerTech V6 215hp 235lb/ft
Rep:4421
If budget is the concern, I would do the O2 sensor first. The misfire can have several causes, plugs need changed, bad coil, leaking fuel injector or vacuum leak on that cylinder. You can always take that coil and swap it with one on the opposite bank and see if the code follows. That will help determine if that is the cause.
Old 05-20-2019, 09:55 AM
Color: Brownish
Ok well I checked plugs and coil and turns out plug coil 4 was crap now to just get the new one put in. Thanks for the tips and help guys
