heat blows cooler on drivers side - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 4th Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 12-04-2018, 10:51 PM
SawdustJ's Avatar
SawdustJ SawdustJ is offline
Vehicle: 2010 Dodge Ram 1500 Quad Cab
Rep:33
SawdustJ is on a distinguished road
You can try to flush the heater core while leaving the truck intact except for removing the heater lines from the core right at the firewall. It's really not that hard to do, just a bit of fussing. The AC lines will not need to be touched.
If you've tried this and it doesn't solve the problem, or you've otherwise determined the heater core needs to be removed, then the AC will need to be evacuated and the lines disconnected at the firewall right beside the heater core connections.
Mods: Extang Tri-fold Soft Tonneau Cover, Bed Liner, Volant CAI, Cabin Air Filter
Old 01-15-2019, 11:17 AM
jdokan jdokan is offline
Vehicle: 2014 Ram 2500
Trim Level: Limited
Color: Black w Silver trim
jdokan is on a distinguished road
Default No Heat Drivers side
I suspect the flushing as a fix for me as my 2014 has very hot hoses both in and out....So I think the core is getting heat.... This is really strange situation...I would think if the issue is a door not opening then I would get restricted air flow...flow is there just not hot...???
Old 01-15-2019, 03:09 PM
ajpillz ajpillz is offline
Vehicle: 2013 Ram
Trim Level: Ext. Cab Express
ajpillz is on a distinguished road
So I switched out the Heater Core in mine about a month ago and the core was defiantly plugged. My inlet and outlet hoses were hot as well and the flush didn't did nothing to unplug mine. Based on the heater core design the it could be 90% plugged and both inlet and outlet lines could be hot. The Core is like a tank that fills up vs a routed line that goes back and forth like a snake and eventually exits. Idk if I am explaining that very well but the coolant doesn't go through a directional path, it just pressurizes the core and the coolant circulates in and out at random. Hints why we are all having this problem. Its a bad design. However a positive to that is we don't get varying heat went the T stat opens and closes. shrug.
Here is a picture of mine cut open. kind hard to see but it almost looks like an epoxy resin that is clogging the ports.
I ended up flushing the system with cleaner several times, replaced the Heater Core, Radiator, Radiator Hoses, and the water pump (mine was fine just added insurance due to miles).
Blows heat so hot it will burn your hands if you leave them there to long
No heat on Driver side 2002 dodge ram rivanco23 Newbie Checkin! 8 02-10-2014 08:33 AM
Getting heat on only passenger side yankeefan4ever Heating & Cooling 26 02-05-2014 10:54 PM
Heat on one side only mopar02 Electrical 13 07-01-2011 11:22 AM
A/C only works while driving, heat works on one side jbbates Heating & Cooling 1 10-15-2009 11:29 AM
No drivers side heat.. maddawg Heating & Cooling 2 12-02-2008 08:10 PM
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019 VerticalScope Inc. All rights reserved.
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
