Camshaft problems 2015 + - Page 3 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > LD RAM - General Discussion
LD RAM - General Discussion RAM 1500 General Chat. Please post your tech questions in the HELP Zone!
Old 04-13-2019, 05:08 PM
Color: MAXIMUM STEEL
Rep:824
I would rather change the cats than a camshaft and lifters.
Old 04-13-2019, 06:30 PM
Thunderhorse's Avatar
Thunderhorse Thunderhorse is offline
Super Moderator
Trim Level: Lone Star (MJX8)
Color: Bright White (PW7)
Rep:931
Thunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to behold
This guy seems to think ZDDP is not necessarily the answer, but what matters is the film strength
https://540ratblog.wordpress.com/201...-test-ranking/
Thunderhorse:
2013 Ram 1500 Lone Star Quad Cab 4X4. Bright White (PW7), 345ci Hemi V8, 8HP70, 3.21 gears (LSD rear). Mods list
Colt:
2015 Durango SXT Southwest Heat RWD. White Knuckle (PW7), 220ci Pentastar V6, 845RFE, 3.45 gears (open). Huskyliners, Catch can. Thread
Old 04-14-2019, 11:55 AM
striker2237's Avatar
striker2237 striker2237 is offline
Vehicle: Ram 1500 "Supermagnum"
Trim Level: 6.7L/408CI+NOVI 2000
Color: Bright Metalic Silver (PS2)
Rep:255
striker2237 is a jewel in the roughstriker2237 is a jewel in the roughstriker2237 is a jewel in the rough
Yes and no, film strength is great but only really matters for the bearings since in our case the lobes are not under pressurized oil feed. The additives allow a "layer" of zinc to form that wears instead of the parts that is renewed via splash that more modern oils can't provide since they simply do not have an equivalent product in them. The above test was also called out as having some errors on BITOG since it ONLY cares about film strength and not any of the other quite important factors.
This is why a modern oil will wipe out a flat tappet cam but allow crazy tight bottom ends (BMW S engines) to live just fine.
Old 04-14-2019, 12:06 PM
Super Moderator
Rep:931
What about the Castrol with titanium? I suppose that is there to serve a similar function to zinc?
Thunderhorse:
Colt:
Old 04-14-2019, 12:08 PM
slickracer slickracer is offline
Vehicle: 2018 Ram 1500
Trim Level: Big Horn Crew Cab
Color: Maximum Steel
slickracer is on a distinguished road
That is the only reason it is not used, to save the cats. It's also what I meant by use better oil.
The need for high ZDDP went away with the introduction of rollers lifters, flat tappets have not been used in a factory pushrod V8 for years.
Old 04-14-2019, 12:27 PM
Rep:255
Then why do racing oils all still use it? It’s not strictly needed it is superior
The major error with that blog is that he does his tests at hot operating temp, while he opines that most wear occurs when cold. He should adjust the testing to reflect that statement.
Old 04-15-2019, 02:39 PM
reefer451's Avatar
reefer451 reefer451 is offline
Vehicle: 2014 Ram 1500 4WD Quad Cab
Rep:60
reefer451 will become famous soon enough
Originally Posted by Mojack View Post
I'm liking the sound of that but could the ZDDP (zinc) be a problem for the emissions equipment?
I think the possibility of that is greatly overblown. Maybe if your engine is burning a quart every 400 miles ZDDP might poison the cat but if your engine is like mine where it doesn't use a quart in 7,500 miles no way ZDDP is going to hurt anything.
Old 04-15-2019, 08:36 PM
Rep:824
I haven't been able to find this guys credentials any where. Seems to be a self proclaimed expert..
Old 04-16-2019, 03:43 PM
Omac's Avatar
Omac Omac is offline
Vehicle: 2013 RAM 1500
Rep:134
Omac will become famous soon enoughOmac will become famous soon enough
I've been adding ZDDP for a couple years now. My engine runs the same as it always has. Scotty Kilmer from Youtube suggested it in one of his segments on the cam lobe problems with the Hemi.
Mopar Hood Deflector, Mopar Mud Flaps Front/Rear, Fire/Ice Mud Flap LEDs, Tonno Bed Cover, Mopar Bed Mat, Mopar Tailgate Liner,Window Tint, Husky WeatherBeater Floor Liner Front/Rear, Mopar Chrome Gas Door
I solved my camshaft sensor issue mikosiko 4.7L PowerTech V8 Specific Topics 5 04-09-2019 03:37 PM
Can you add air ride to a 2015 Laramie stormcom 2015 Dodge Ram Forum 20 06-17-2015 04:06 PM
Diablo i-1000DCX not work on 2015 models? Northshoremb Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 14 04-07-2015 06:57 AM
2016 Ram Ordering June/July 2015 :) GTyankee LD RAM - General Discussion 12 02-21-2015 09:10 PM
