Replacement Tires - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > 2016 Dodge Ram Forum
2016 Dodge Ram Forum For specific discussion of the 2016 Dodge Ram!
Old 05-14-2019, 09:28 AM
14Hemi's Avatar
14Hemi 14Hemi is offline
Vehicle: 2016 Ram 1500 CC Big Horn
Rep:190
14Hemi has a spectacular aura about14Hemi has a spectacular aura about
Originally Posted by Thunderhorse View Post
I am running the LT 275/60/20 BF Goodrich KO2s. They are a D load range and I just installed my second set after getting 61,000 miles out of the first set
Do you recall if they were the "DT" tires or the severe weather rated?
2016 Big Horn Hemi 4x4 w/ 3.21 Limited Slip
Bilstein 5100 at 2.1", Timbren SES, Airlift 1000, 18" Magnaflow, AEM Dryflow, 34" Falken Wildpeak AT3W, H9/9011 Headlight Upgrade, 7'6 Fisher HT, Bullet bedliner
Old 05-14-2019, 09:33 AM
namretsud's Avatar
Vehicle: 15 BigHorn Ecodiesel
Trim Level: Big Horn CC
Rep:287
namretsud is a jewel in the roughnamretsud is a jewel in the roughnamretsud is a jewel in the rough
I went with the AMP Terrain Pro tires in the stock size. The are the same 33" tires as the SRA crap ones and are e-rated and are severe rated with the snowflake on them. They are an exact match to the K02 tread pattern, but have a 60k mile warranty and a lower price. K02's do not have a mileage warranty.
Old 05-14-2019, 11:35 AM
Thunderhorse's Avatar
Thunderhorse Thunderhorse is offline
Super Moderator
Trim Level: Lone Star (MJX8)
Color: Bright White (PW7)
Rep:931
Thunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to behold
What do you mean by "DT" tires? They have the little snowflakes on them
Thunderhorse:
2013 Ram 1500 Lone Star Quad Cab 4X4. Bright White (PW7), 345ci Hemi V8, 8HP70, 3.21 gears (LSD rear). Mods list
Colt:
2015 Durango SXT Southwest Heat RWD. White Knuckle (PW7), 220ci Pentastar V6, 845RFE, 3.45 gears (open). Huskyliners, Catch can. Thread
Old 05-15-2019, 06:51 PM
Maloney4tn Maloney4tn is offline
Maloney4tn is on a distinguished road
Try this site...
https://www.tacomaworld.com/tirecalc
You can plug in your stock tire size and any you want to consider, and it shows the diff in your Speedo so you can decide to bother with that or not.
I’m moving from stock to 35x12.5x20’s, so the difference is only 4mph at 65mph. Therefore not worth it to me to recalibrate.
Old 05-15-2019, 08:20 PM
Gymwear Gymwear is offline
Vehicle: 2015 Ram 1500 Sport
Color: Dark Red
Gymwear is on a distinguished road
I swapped for Michelin Dfenders in same size but beefier...I had serious problems wth SRA's...gravel roads bruised center ply on two tires same day ruined tires...will never use SRA's or GY again...Michelins are stiffer but get basically the same mpg
Old 05-15-2019, 10:56 PM
steelhorsecowboy's Avatar
steelhorsecowboy steelhorsecowboy is offline
Vehicle: 14 Ram 2500
Trim Level: Lonestar
Color: Grey
steelhorsecowboy is on a distinguished road
I ran LT275-65-20E dura trac tires and had no problems. Cleared by a fingers width and looked nicer too as it filled the wheel well more.
Old 05-16-2019, 12:35 AM
Hank McMauser's Avatar
Hank McMauser Hank McMauser is offline
Vehicle: 2015 Ram 1500 x2
Trim Level: Bighorn
Color: Granite Crystal Metallic/White
Rep:16
Hank McMauser is on a distinguished road
I just put the BF Goodrich KO2 all terrains on my 2015 bighorn. I did so on many recommendations by folks here(Thunder horse) load range D with 58 psi cold when towing, and 45 when empty. I pulled my 7000# keystone Bullet across the country, and have been very satisfied with their performance. Both on and of road.
I also added 1000 series air bags inside the coils, and run them about 13-15 psi when towing. Any more pressure in the bags, and it starts to feel like you're in a small boat coming in with the waves.
2015 Bighorn hemi 8sp ,3.21 quad cab GCM.
