Where's the horn supposed to be? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Electrical
Old 05-14-2019, 09:34 PM
bmax1985's Avatar
bmax1985 bmax1985 is offline
Vehicle: 2007 Dodge Ram Sport 4X4
bmax1985 is on a distinguished road
Default Where's the horn supposed to be?
I have recently acquired a '97 Ram 1500. One of the items on my list is to figure out why the horn doesn't work. Relay clicks, cruise buttons work, no air bag light so I don't think it's the clockspring. Thing is, I can't find a horn or the bracket (based on the image in my Alldata manual). I'm wondering if it's just not there and what it should look like.
Thanks!
- Brian
Old 05-15-2019, 01:02 AM
Rep:3053
Look at the drivers side near the front bumper
Old 05-15-2019, 07:40 AM
bmax1985's Avatar
Thanks. I'm pretty sure it's gone. Do you know what color the wires to the wiring harness are? I'll take a new approach and look for that.
- Brian
Old 05-16-2019, 02:09 AM
Rep:3053
I just found something to check out
Question;
2005 dodge ram 1500: the horn wires..purple wire..fender…
I am trying to locate the horn wires for a 2005 dodge ram 1500 pickup. I need to find a dark green and purple wire under the fender, can you help me locate it or tell me where to look?
Answer;
The horns are under the left fender and you can get to those wires there. An easy way to get to the horns is to remove the left inner fender plastic shield. remove the 8 mm screws holding the fender shield and let it drop down a little. Then look up and you will see the 2 horns.
another answer;
Yup, you can see it if you pull the driver side headlight. 3 10mm bolts and a flat blade screwdriver will get you at it pretty quick.
Old 05-16-2019, 06:27 AM
Moparite's Avatar
Moparite Moparite is online now
Vehicle: 96 Indy ram - 96 2500 4X4
Rep:16
Moparite is on a distinguished road
What does a 2005 have to do with a 1997? You should have two horns, Lift the hood and look behind the bumper. I believe they are mounted on the radiator support.
Old Today, 02:17 PM
stardude900's Avatar
stardude900 stardude900 is offline
Vehicle: 1998 Ram 1500
Color: Silver and Black
stardude900 is on a distinguished road
I have a 98, I'll double check mine but I believe it is on the passenger side near where the headlight is. I'll look for some wire colors too.
