Trailer Not Connected - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > HD RAM - 2500 | 3500 | 4500 Ram Truck Forum > HD RAM - TOWING
HD RAM - TOWING All about towing with the big dogs!
Old 01-09-2019, 03:15 PM
ManlySheep ManlySheep is offline
Vehicle: 2015 Ram 1500 Quad Cab
Trim Level: Tradesman
Color: Charcoal
Engine: 2014-20?? 182ci (3.0L) L630DOHC V6 240hp 420lb/ft Eco-Diesel
ManlySheep is on a distinguished road
Default Hello and thanks!
Hi gang, I've just signed on for the first time and I want to start off by saying thanks to Monster5601 for the tip that the trailer brakes can be tested by engaging the breakaway switch. I jacked up one side of the trailer, pulled out the breakaway switch and confirmed that the brakes were engaged (I could not turn the wheels). I repeated the process on the other side with the same result. So I figured it was either the truck's fault or the wire from the connector to the junction box was bad. But when I reinserted the breakaway switch and started the truck, the problem was gone! I'm a little puzzled about why that fixed the problem, but I'll take it. I guess it's possible the contacts on the breakaway switch had gotten corroded and somehow confused the truck's trailer brake connection circuitry, and removing/reinserting it cleaned them. But it's an easy thing to try if you're having this problem.
Old 01-09-2019, 08:29 PM
wideopenthrottle wideopenthrottle is offline
Vehicle: 2018 Ram 2500
Color: Blue Streak Pearl/Silver
wideopenthrottle is on a distinguished road
Default How to avoid a step
In the future you could just pull the brake-away plug/pin and then drag the trailer to see if the wheel's turn or lock-up. Saves the time of jacking it up. The one advantage of jacking it up would be to check the bearing play.
Ram owner since 1994,Amp Powersteps,Bumperstep,OPT 7 LED light Bar, Western MVP 3 V-Plow
Old 01-09-2019, 11:41 PM
redwagon redwagon is offline
Vehicle: 2016 ram 2500 powerwagon
Trim Level: power wagon crew cab
Color: delmonico red pearl
redwagon is on a distinguished road
I had the same thing happen to me last year on the way home from a snowmobile trip in Canada with the message of trailer not being connected. Tuns out this year when I took the trailer for inspection it had a bad(intermittent functioning brake magnet ) and also a break in the wire on that same wheel. I got the trailer back and after being repaired the message has not come back.
Old 02-15-2019, 11:18 PM
Texomahog's Avatar
Texomahog Texomahog is offline
Texomahog is on a distinguished road
I have the same issue with my new 2500. Brakes on the old dump trailer work fine. The truck will not recognize the new 24 ft. equipment trailer I have. The trailer dealer says its a truck problem and the Dodge dealer says it's a trailer problem, which I guess means it's my problem now. I really have not had time to mess with it yet.
Old 05-14-2019, 05:41 AM
Texomahog's Avatar
Default I'm a mechanical genius
The wires were not hooked to the brakes at the axle. As my dealer said the trailer was okay I never thought to look there. Talk about feeling stupid!!! Brakes work great now. LOL
