TLC for 2014 RAM 2500 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Accessories - Dodge Ram Parts - Dodge Ram Performance - Registered Vendors! > Total Load Control - Dodge Ram Air Suspension
Total Load Control - Dodge Ram Air Suspension TLC™ is the patented air suspension that solves the problems hauling or towing heavy loads with coil springs. No modification required; keep the coil springs. Fits all 2009-16 RAM 1500 including Ecodiesel and 2014-16 RAM 2500! Spacers available for most 4" and 6" lift kits for RAM 1500
TLC also makes units for 02-13 RAM 2500 & 02-16 RAM 3500 with leaf springs.
TLC adds over 5,000 lbs of lifting power to level any load or tow with the largest air springs on any full-size pickup – 9” Goodyear® dual bellows. Your truck will be safer, handle better and go faster around curves. TLC doesn’t interfere with the factory ride. You’ve never experienced the power of air bags until you try Total Load Control™.
Easy to install; no drilling; fits leveled & body lifted trucks.
We introduced TLC on the Z and have many happy Z customers. Get Total Load Control Today !
Old 10-20-2014, 07:26 AM
TLC John's Avatar
TLC John TLC John is offline
Vehicle: 2006 Dodge RAM
Rep:17
TLC John is on a distinguished road
Default TLC for 2014 RAM 2500
TLC is available.for the 2014 RAM 2500.
While the RAM 2500 with coil springs improves everyday ride, even this heavy-duty truck sags under heavy loads.
TLC adds over 5,000 pounds of lift with two 9" Goodyear® air springs that bolt-on next to the coil springs (no modification required)(never exceed GVWR or GCWR).
As with TLC's other products, your truck will be level hauling or towing even at the max GVWR or GCWR - and TLC's patented system does not interfere with the smooth factory ride.
As with other TLC suspensions, use with any external air source - a hand-held compressor, TLC's wired air compressor kit - or we recommend the WirelessOne wireless air compressor system.
Competitively priced at $499.
Please let us know if you have any questions or check out our webpage about it:
http://www.totalloadcontrolsuspensio...pring2014.aspx
Of course, TLC is available for
- 2009-2014 RAM 1500
- 2002-13 RAM 2500
- 2002-2014 RAM 3500
Total Load Control™
Revolutionary Air Suspension for RAM 1500 2500 3500 4500 5500
Level Every Load with TotalLoadControl.com
Old 03-10-2018, 02:07 PM
FloridaMark FloridaMark is offline
Vehicle: 2017 Ram 2500 Cummings 4x4
Color: Grey/silver
FloridaMark is on a distinguished road
Are you still in business? And do you make them for the 2017 2500?
Bilstein 5100,Nitto Grappler G2,Weather Floor Mats,Line-X,BAKFlip F1 Tonneau,LED's Lights
Old 03-19-2018, 04:59 PM
G. Mcpherson's Avatar
G. Mcpherson G. Mcpherson is offline
Vehicle: 2018 Ram 2500 4x4
Trim Level: Big Horn Crew cab
Rep:20
G. Mcpherson is on a distinguished road
Out Of Business.
