Any thoughts on spacers? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 01-11-2011, 06:50 AM
zaroba zaroba is offline
Vehicle: 2000 Dodge Ram 1500
zaroba is on a distinguished road
Default Any thoughts on spacers?
anybody here use wheel spacers?
mainly, the bolt on ones that have their own lugs to attach the wheel to.
are their any pros/cons? how do they affect driving? i figure the wider wheelbase makes it more stable, but any other effects?
such as these ones from ezaccessory.com
Old 01-11-2011, 09:30 AM
Rep:3347
They are a viable tool for two things: moving your backspacing of your current rims by more than 1/4" safely, and for changing your lug pattern. Yes, the wider wheelbase is more stable, but you are putting a torsional load on your hub and suspension by moving the load out beyond the centerline; you will end up with a slight negative camber. Also,if you lower the vehicle, it will make you more susceptible to rubbing on the inner fender.
They ARE the best way to move the wheel out from the hub, so if you're looking to do it and can't find rims with the negative backspacing you want, then go for it. I recommend using red locktite on your lugnuts and torque them to ensure even pressure on the plate, don't just use an impact gun. Then you can treat the other studs like normal, but I still recommend torquing them, and not using an impact.
Old 01-11-2011, 09:51 AM
BLKSVT's Avatar
BLKSVT BLKSVT is offline
Vehicle: 2010 Ram 1500 4X4 Hemi
Color: Brilliant Black Pearl
Rep:222
BLKSVT has a spectacular aura aboutBLKSVT has a spectacular aura aboutBLKSVT has a spectacular aura about
Just how do these install, I see a 5 studs with nuts...then 5 holes...sorry for hijacking but just wondering.
"MPG???...I get Smiles Per Gallon!"
2010 RAM SPORT CC 4x4 Hemi
Diablo Tuner, Mufflex 14, Bilstein 5100 leveling shocks, 3.5 lift, 35 in mud tires
Old 01-12-2011, 06:43 AM
ty for the reply cdnoil
blk, they bolt to the hubs using the holes just like your wheels do, then the wheels bolt to the spacers via the studs with nuts on the spacer.
Old 01-16-2011, 11:26 AM
GregInAtl's Avatar
GregInAtl GregInAtl is offline
Vehicle: 2012 Ram 1500 QC
Color: Dk cherry red
Rep:130
GregInAtl will become famous soon enoughGregInAtl will become famous soon enough
I use them on my Grand National. It makes 2x the power of these trucks and has never had an issue. I use 1.25" btw.
12 Ram express QC, belltech 963sp and McGaughys spindles, debadged,Polk audio, smoked lights, tint, bedcover, and lots more
06 Stratos 201 Pro XL 225 Yamaha
Old 01-16-2011, 12:04 PM
cyberpine cyberpine is offline
Vehicle: 2012 Ram Hemi regular cab 2wd
Rep:53
cyberpine will become famous soon enough
On my 2010 4x2 Ram 1500 I'm looking at the amount of meat of tread and it would seem like it can accomodate a 1/2 inch spacer.
How many times would you guyz say the nut needs to spin to be considered safely attached securely/safely to bolt?
Any drawback to having my stock 2010 chrome clad rims stick out an extra 1/2 .. alignment? handling? mpg cost?
something like this:
stock below without the 1/2 inch (non bolt on) wheel spacer.
Thanks!
http://www.cyberpine.com
2012 Red Ram 1500 Hemi Regular Cab 2wd
*Can I run 18x9 -12mm offset with 33x12.5x18 on a stock 4th Gen 2 wheel drive? How about 20x10 -24 33/12.5 on a stock 4th gen 2 wheel drive? * Any 4th gen with a 2nd or 3rd gen camper shell?
Old 06-09-2019, 06:29 PM
thomasspink's Avatar
thomasspink thomasspink is offline
Vehicle: 2019 Ram 1500 Classic Big Horn
Color: Diamond Black
Rep:76
thomasspink will become famous soon enough
sub'd
2019 Ram 1500 Classic, Crew Cab, Big Horn, Black Appearance Group 8.4 NAv
Rep:76
Looking at getting 1.5 " spacers to my 2019 classic, i like the look and style of the stock black 20" rims and would like them to stick out a little more. especially after adding in some fender flares
Old 06-11-2019, 09:49 AM
joeyg's Avatar
joeyg joeyg is offline
Vehicle: 2016 1500 Sport Crew White
Trim Level: Sport Crew
Rep:47
joeyg is on a distinguished road
I've got 1.5" Bora Hubcentric spacers for my winter rims (with OEM Sport 20's) to push my wheels out a bit so they don't look lost with my Bushwacker Fender Flares.
2016 Ram 1500 Sport Crew Bright White, 5.7 litre Hemi, 3.92 Axle Ratio, 4" Superlift Lift Kit, XD Rockstar 2's 20x9 (-12mm offset), 35x12.5x20 Cooper STT Pro's, Bushwacker Pocket Fender Flares, RetraxOne MX Retractable Tonneau Cover, Mopar Bedrug, DeeZee Tailgate Assist
Old 06-13-2019, 09:55 AM
Rep:76
pictures?!?!?!
