2020 Ecodiesel - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - News Desk > Automotive Industry News and Dodge Press Releases
Automotive Industry News and Dodge Press Releases News regarding the Dodge Ram and other industry info. Post it here!
Old 06-10-2019, 11:59 AM
14Hemi's Avatar
14Hemi 14Hemi is offline
Vehicle: 2016 Ram 1500 CC Big Horn
Rep:214
14Hemi has a spectacular aura about14Hemi has a spectacular aura about14Hemi has a spectacular aura about
Thumbs up 2020 Ecodiesel
The specs on the new Ecodiesel have surfaced and it's good news. The ecoD is available in every trim level including the Rebel. There's not only 60 ftlb more torque and 20 hp more, but the torque comes in at 1600 rpm rather than 2000 rpm as in the previous ecoD.
The peak hp is up pretty high at 3600 rpm's, only the baby duramax peaks hp at a higher rpm: 3750. The baby Dmax has peak torque lower though at 1500 rpms.
The baby powerstroke has peak torque at 1750 rpm and peak hp at 3250 rpm.
The ecoD has the highest torque and 17 hp less than the GM twins but 10 hp more than Ford.
The tow ratings are a big increase, I look forward to the test results on TFL Truck.
https://www.cnet.com/roadshow/news/2...ck-comparison/
2016 Big Horn Hemi 4x4 w/ 3.21 Limited Slip
Bilstein 5100 at 2.1", Timbren SES, Airlift 1000, 18" Magnaflow, AEM Dryflow, 34" Falken Wildpeak AT3W, H9/9011 Headlight Upgrade, 7'6 Fisher HT, Bullet bedliner
Old 06-10-2019, 01:02 PM
guy65's Avatar
guy65 guy65 is online now
Vehicle: 2014 RAM 1500 CC 6.4' 4x4
Color: Caucasian
Rep:100
guy65 will become famous soon enoughguy65 will become famous soon enough
The available payload will break it's neck- it says, it can tow 12000#- but I bet, a trailer that heavy will probably max the available payload out. Beside 12000# with a half as heavy half ton is bit much.
Opinions are like buttholes- everybody has one.
Old 06-10-2019, 01:20 PM
14Hemi's Avatar
Rep:214
I agree, I wouldn't tow that heavy with a half ton on a regular basis, but, if I could take a dump trailer to get a few yards of gravel, topsoil, or mulch it would be great. I can do it with a hemi and 3.92 gears, but if I can gain the efficiency of the ecoD, it would be nice.
I also think it would be nice to have the small diesel for towing the camper trips because it is a HUGE pain in the @ss to consistently find a gas stop with a large enough pull through gas pump for my truck and trailer; with the bike racks on back my trailer is about 36' long.
The last ecodiesel was too much of a payload penalty when compared to the hemi and only marginally out-towed a 3.21 equipped hemi truck when the ecoD was paired with 3.92 gears.
I expect to see about a 1500# payload, that seems to be about where it would fall with an SLT trim CC 5'7 bed. The previous ecoD version already has a CGI block, so I don't expect that much weight was trimmed from changing the pistons out in the revised ecoD, but we'll see.
Old 06-10-2019, 07:05 PM
Thunderhorse's Avatar
Thunderhorse Thunderhorse is online now
Super Moderator
Trim Level: Lone Star (MJX8)
Color: Bright White (PW7)
Rep:931
Thunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to behold
I was expecting FCA to wait until GM released their output numbers before announcing the next gen Ecodiesel. They're calling this the gen 3 though I don't remember a gen 2.
It is good to see though that the max towing is on par with the Hemi, so it looks like the payload will be the only thing that suffers for the tradeoff of fuel efficiency. Hopefully this new EGR system and the upgrades solve the issues the previous versions had
Thunderhorse:
2013 Ram 1500 Lone Star Quad Cab 4X4. Bright White (PW7), 345ci Hemi V8, 8HP70, 3.21 gears (LSD rear). Mods list
Colt:
2015 Durango SXT Southwest Heat RWD. White Knuckle (PW7), 220ci Pentastar V6, 845RFE, 3.45 gears (open). Huskyliners, Catch can. Thread
Old 06-11-2019, 03:48 AM
Rep:3060
It makes me wonder about something .....
If you tow 12,000 lbs, in your State, what drivers license do you need ?
Do you need to cross the truck scales on the highways ?
Old 06-11-2019, 09:52 AM
canadian.bacon's Avatar
canadian.bacon canadian.bacon is offline
Vehicle: 2019 Ram Classic
Trim Level: Night Edition
Rep:132
canadian.bacon will become famous soon enoughcanadian.bacon will become famous soon enough
in Ontario you can tow up to 10,141 lb on a regular license, after that you need other stuff. They are very specific about the trailer being 10,141 lb (4600kg) or less.
Old 06-13-2019, 02:48 PM
14Hemi's Avatar
Rep:214
If towing more than 10,001 lbs or a GCWR of 26,001 lbs a CDL A is needed in NH. It also depends on the state laws, typically a truck references a truck used commercially, not privately, so campers are typically not falling under the commercial licensing requirements.
Old 06-13-2019, 07:33 PM
Rep:3060
California also limits Class C drivers to 10,001 pounds
I carry a Class A, but without any endorsements, i dropped doubles & triples, tankers, hazmat, etc.
Heck, i am 75 & i would only be driving a semi if a trucker were to get sick on one the Over Size Loads that i escort & then only if the company can not get another driver in a reasonable amount of time.
2020, ecod, ecodiesel, ram 1500, updated
