2010 Laramie locked in Park ESC light on and Anti theft flashing - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 06-12-2019, 03:29 PM
Ian Radanke Ian Radanke is offline
Vehicle: 2010
Ian Radanke is on a distinguished road
Default 2010 Laramie locked in Park ESC light on and Anti theft flashing
Hi All hope somebody can give me some hints. As I am in the UK going to the dealer is not an option.lues
So let me talk through what happens. Car will lock unlock easily with remote so as understand wireless ignition node is good?
Key put in says "key inserted" so key is recognised? Next turn key anti theft light begins to flash and the ESC light illuminates and stays on.
Now within the Display mode "Park assist system off" comes up as does the red battery symbol. Gauge shows 3/4 for battery and when checked is around 12.7 - 12.8 Volts.
There is no Gear selector position shown . The gear shift is locked , pressing brake does not release it.
The engine does not turn over or make any attempt. to.
If I try remote start it says malfunction.
When I return key to off position it tells me key still in. Does this mean the key is being detected and so the memory has not been lost and the immobiliser circuit is recognising it as the correct key?
It does this with both my keys.
Thoughts?
Thanks for any help
Old 06-12-2019, 11:58 PM
sottis sottis is offline
Vehicle: 2010 Dodge Ram Laramie 4x4
sottis is on a distinguished road
Try a new battery or jumping the current one. Your voltage is low.
Old 06-13-2019, 05:16 PM
Vehicle: 2010
Thanks Scottis.
Problem resolved was a loose overcam connector. Went back through steps I had been doing and must have got knocked. Was checking all cam locks tried this one all works perfect .
Hope it helps anybody else who has a similar issue
