Where is that Oxygen sensor? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 06-11-2019, 06:41 PM
DBrockett DBrockett is offline
Vehicle: 1992 Ram D250
Trim Level: LE
Engine: 1992-1993 318ci (5.2L) Magnum V8 230 hp 280lb/ft
DBrockett is on a distinguished road
Default Where is that Oxygen sensor?
Maintenance required light=Oxygen Sensor
Got the book and the online manual but still having trouble locating this sensor. It isn't on the manifold but I can't find it on the exhaust either. Anyone else with a 1992 D250 5.2L that has changed this part?
Old 06-11-2019, 08:22 PM
Rep:3060
You should first take the vehicle to a chain type auto parts store & request that they connect up their scan tool, most people go to either Autozone or Advance Auto, but other places have the scan tools too
The scan tool will show what code(s) have been set
Knowing the code(s) will tell you what part or parts are actually bad
Writing down the code(s), going online to this site, find the code in the P code list
https://www.obd-codes.com/trouble_codes/
Old 06-12-2019, 03:02 PM
Gen1dak Gen1dak is offline
Vehicle: 1991 RamCharger
Rep:99
No, Maintenance Required light = time to pay dealer stupid money to turn the light off and over charge for basic maintenance, and non-necessary BS.
A faulty O2 sensor doesn't usually trip an engine light. It will, however, cause the engine to run rich, eventually getting so bad it will belch black smoke and water those eyes. An added bonus is you can watch the fuel needle move towards empty just like the old days when flooring it in a carbureted Big Block muscle car. By that point, you're dumping so much gas, the cat is being damaged. As to the O2 sensor, which is probably well into it's useful lifespan, get under the truck and look to the single exhaust pipe in the section between where the 2 pipes join, and where the catalytic converter is.
Old 06-12-2019, 04:58 PM
Rep:3060
Pre 2000 chrysler products had either 2 or 3 Oxygen sensors
2000 & newer chrysler products had 4 sensors
The o2 sensors in front of the catalytic converters are called Heated o2 sensors
Old 06-12-2019, 07:21 PM
Moparite's Avatar
Moparite Moparite is offline
Vehicle: 96 Indy ram - 96 2500 4X4
Rep:16
Moparite is on a distinguished road
92 was the first year for the 5.2 magnum, If you have the magnum you have two 02's one before the cat and one after. If you still have the LA motor it's one 02. And as said "maintenance required" is just a timer that goes off after a certain amount of time. It has nothing to do with the "check engine light".
Old 06-12-2019, 10:45 PM
bspRAM bspRAM is offline
Vehicle: 2018 RAM 1500 CC
bspRAM is on a distinguished road
I agree with the replies indicating the "Maintenance Required" message is probably not driven by an actual fault, just an algorithm (mileage and maybe how the vehicle is driven).
Is your check engine light (CEL) on ? How many miles on the truck ? O2 sensors can go up to 100K miles or more, but recommended replacement is usually more like 60K, since they get lazier with time and the signal of the pre-cat sensor is used to control your ECU. If you go way long, you might damage your cat.
GTyankee linked a nice you tube on the replacement. If I had more than 60K on the sensor, I might replace it DIY. Then find out on line how to reset the message and drive with confidence.
bspRAM
2018 Laramie 1500 CC, Peragon bed cover, Rhino spray-in bed liner, OE bed lights, OE tow hooks, OE w-to-w tubular side steps
Old 06-12-2019, 11:07 PM
Default addendum - turning the reminder light out is hard . . . .
All that I could find on the web was that for 89-95 Dakotas the light only resets via an obsolete "OBD I" tool that many dealers just no longer have. It is programmed to come on with mileage.
It is only a "reminder", so many have either taped it over with electrical tape or removed the bulb. One intriguing POSSIBILITY is that it might turn itself off after some predetermined number of restarts - but that's just a thought that I saw no data to support.
bspRAM
Old 06-13-2019, 01:45 AM
Rep:99
According to the FSM on my '91 RC, the maintenance light is programmed to come on at specific mileage points. I've also read where these things can be set to illuminate after a preset number of operating hours.
Old 06-13-2019, 01:52 AM
Rep:99
OBD I Magnums ('92-'95) only have pre cat O2 sensors, and since they had a single pipe and a single cat, that means they had 1 O2 sensor upstream of the cat. Power was supplied to cause it to heat more quickly in an effort to reduce the time it took before the O2 sensor began operating after startup, thus reducing emissions during initial warm up. It is the OBD II Magnums ('96 and newer) that have both pre and post cat O2 sensors, meaning they have at least 2, or as many as 4 (on dual exhaust models).
Old 06-13-2019, 01:59 AM
Rep:99
It'll burn out eventually.
bspRAM
o2 sensors
