1 - 7 of 7 Posts
Discussion Starter #1
Anyone , ever had or having this problem ? Dash lights up , power to every thing turn the key to start and nothing !!
If your battery is 3-5 years old, it may be time to change it. At the very least have it load tested.
Discussion Starter #3
Thx for the reply, let me tell you ware im at with this thing , new battery , starter relay , tested starter (good) and I don’t believe it’s in the switch any thought appreciate it
You might check under the steering column. There is a yellow 10-12 gauge wire under there that I had get pinched and stop the truck from starting on my old 2000 ram 1500. It powers the ignition switch. I replaced the pinched section and it started up fine. I also wired in a on/off push button switch and hid it for a great kill switch.
Discussion Starter #6
Thanks for the input , so I’ve crawled all up under the dashboard and tried the neutral start over and over and then it just started 10 x over again and then I guess it has a mind of its own have not a hit for rest of the day no start , neutral safety switch ??? Or ignition?? Watcha thinking ?? Thx
Could replace the neutral start switch on the transmission. Cheap to buy and will eliminate a source. Glad that you got it to work for now. Check the wiring harness connectors for corrosion.
1 - 7 of 7 Posts
