1 - 2 of 2 Posts
Discussion Starter #1
hey all is there anyone making an actual dash replacement and not just a pad?
or what years interchange? i might have a lead on a 06 dash
im not wanting to swap electrical, just the top panel that is all busted up
also anyone know what size bulbs the instrument cluster takes?
im taking my dash out to fix the blend/mode door problem and if possible i would like to fix stuff
thanks
Stick to 02-05, the 06-08's have fitment and color changes. This one will work perfectly (if you have gray and not the taupe color): https://www.ebay.com/itm/04-05-Dodge-Ram-1500-SRT-10-OEM-Upper-Dash-Pad-Assembly-Black/392144795096
Might be a good idea to replace the A/C evaporator while you're in there. My heater core went 6yrs ago and I did the whole nine, dash, core, evaporator, blend door. Of course about 3yrs after that the recirc door broke so I had to do that in place (difficult but not impossible).
Cluster bulb p/n: 4827989AA
1 - 2 of 2 Posts
