03 Ram 1500 Lights Issue
635 Views 2 Replies 3 Participants Last post by  gabrielgonzalez
I have a 2003 Dodge Ram 1500, ST, 4x4, 4.7 Magnum. I have the "bulb out" message, and the entire passenger
(right) side lights are not working other than my low beam. No turn signal, no tail lights, no brake light on right side, even my right license plate is out. I've replaced all fuses and relays. Even replaced the FCM and cleaned and made sure all connections where properly connected. I'm not sure what else to try. All the bulbs are new and the headlight has a whole new assembly. Any advice is appreciated, thank you!
1 - 3 of 3 Posts
Sounds like you have a broken wire.
thanks, my problem was the connecter on the ground battery that we replaced on the left side wires. but now the lights on the license plate is now fixed and the connecter to the led was broken.
1 - 3 of 3 Posts
