1 - 5 of 5 Posts
I know that this has been talked about a lot but my problem seams to be different, and I need to get it repaired. I have an 04 1/2 ram 3500 diesel with auto trans SLT, My wipers work normal when there is no rain, but as soon as it rains my intermittent starts having problems, I can select intermittent and it might wipe once or 2 times each stroke or up to 5 wipes, The timing seams to be ok, I can select low or high and most times it works good, I just went to Reno in a light rain and the wipers had problems, they even stoped in the midle of the windshield. rotated the shitch a few times and started working again. This has been going on for a while but seams to be getting worse (more wipes per stroke ) Could anyone help with this?
Thanks
Under your IPM (AKA Fuse Box) is the FCM (Front Control Module) which controls the wipers among other things. This unit plugs into the IPM with a big multipin connector. I recommend unplugging and plugging back in to cycle the contacts. While your there, cycling the contacts on all the big multipin connectors is a great maintenance item.
Although I don't think this can be done without removing the battery cable, I'll mention to make sure the battery is disconnected before playing with any of this wiring. :)
It is common for these connector to exhibit issues from connector corrosion. I use dielectric grease on mine to reduce the chance/affect of corrosion. :)
1 - 5 of 5 Posts
