1 - 4 of 4 Posts
I have replaced the front drive shaft on my 04 1500 slt 4x4 and now when i turn the key all the bells and lights but nothing happens. It does not even try to turn over.
It started and ran fine before removal. The cv joint on shaft was shot so replaced whole shaft.
I've tried to reset the ecu and it does nothing still.
Any suggestions?
Discussion Starter · #3 ·
Fyi, I had bumped the shift leaver on the transmission and even though it was showing on dash as being in park it was actually in reverse. I only found this out by trying to shift to neutral to start when i shifted the dash light moved 2 clicks and the gear shift had only moved 1. So it corrected itself by shifting all the way to low and back up to park.
Thanks for any input.
1 - 4 of 4 Posts
