1 - 3 of 3 Posts
My speedo stays at zero, (bought it used that way) and I have a BRAKE light and ABS light on, all the instrument gauges work OK, tach works OK. Replaced speed sensor in pumpkin with a new one from NAPA with no results, next move? I need that speedo so I can brag how fast that hemi goes...
I am assuming that you bought the truck used like that, not the just the gauge cluster only.
I would take the gauge cluster out and double check the connections, sometimes the wires can pop out of the harness. I happened to me when I recently changed to gauge lights to blue LEDs. For me it was the tach that wasn't working. If that doesn't help, check to see if the needle is still connected. Don't pull on the needle, just lightly push it in to the gauge. If it doesn't move that just means its not the problem. Since it is electric it could be a number of things. You trace the connections on the circuit board and see if their is a break in any connections. You may need to replace the gauge cluster, however I don't know if the mileage will change or even if it will work. You might get the answer from the dealer. Hope this helps, maybe someone that has had a similar issue will chime in and offer better advice or the solutions to your problem.
Discussion Starter · #3 ·
Thanks for the reply Taco
It ended up being a broken wire to the speed sensor. The dash diagnostics gave me that hint that there was nothing wrong with that cluster to the diff speed sensor.
1 - 3 of 3 Posts
