My '05 1500 HEMI Ram will crank but it won't kick over. Got a bad EGR code (0404) on the reader so I replaced it. I have full battery power (stereo, internal/external lights, instrument panel, alarm, etc.). Starter clutch engages and cranks every time. Fuel pump hums and I get pressure on the rail. Coil pack tester shows spark on both banks. I replaced all 16 plugs with Bosch Platinum. Cleaned the air filter. Cleaned the throttle body butterfly. I even tried to hot start it with carb cleaner and barely got a hiccup.
Any advice will help.
Thank You
Thank You
