I'm trying to replace my old shocks but am currently stuck on removing the bottom bolt connecting the lower arm to the shock. The bolt will spin but I feel like the rubber bushing or whatever is not letting the bolt spin the way it should, it keeps going back to where it started. Any ideas would be awesome.
Mite have some rust around it in the metal sleeve, spray some WD-40 in their, also you will have to smack it with a hammer. Also there is tension against the bolt from the strut/spring. I've done this job a couple of times and it's kind of a PITA.
Thx. Least I'm not alone thinking this sux. I've been spraying this guy down for a bit and it's not working. I was hoping not to use a hammer but will give it a shot.
Gen.1 board is DEFINITELY the right place to be. 1 ton SAS it, and go with some good air shocks, and you'll be riding like a stagecoach in no time! :naughty:
Ok guys, it's been a while and after multiple unsuccessful attempts at removing this bolt I am stumped. I've used almost a whole can of liquid wrench, hours of waiting, and even tried an impact wrench to try and get this thing out. Do I need a light saber or something to melt it and the stupid sleeve out of there or what? At this point I just want to take a sledgehammer to the thing and push the thing out that way. Very desperate here, any advice would be welcome. ?
Related Threads
DODGE RAM FORUM
2.2M posts
201.9K members
Since 2008
We’re the ultimate Dodge RAM forum to talk about the RAM 1500, 2500 and 3500 including the Cummins powered models.
