1 - 20 of 21 Posts
Soo i got the Mcgaughy's kit and completed in the way it should be i got the panhard bar bracket notched so it fits very well ordered custom EVS bump stops to match the rear and i have made my kit adjustable in the front, it is either a 3.25 inch drop or a 2.25 inch drop the Mcgaughys kit sits alittle to level for me so i solved that issue, the only thing i think the truck can benifit from with this kit is either shorter shocks or 24 inch limit straps ( i had straps on mine alot cheaper than belltech shocks ) $300 obo plus shipping heres a pic of the truck with the 3/4 :smileup:
Discussion Starter · #3 ·
Yup it is kit part number 44052 it comes with the tracbar kit which i had fixed so it actually works the whole is alittle to low youll read alot about it on this forum, and also it rides really well with the stock shocks and on McGaughys website and in the intructions it says to use the stock shocks the only reason i put limiting straps in it is because the rear sway arm end links for the kit are super short to keep the proper geometry and when you lift the truck up and let everything hang they get into kind of a weird angle, if you wanted put shocks in it ne ways the belltech street performance ones or nitro drop 2s would be good im sure but at almost 50 per shock the 20 dollars straps and the cushy ride of my stock shocks sounded great plus the 275/55/20 nittos ride super smooth
I have the same exact Body Style, and with your little modification, this should pretty much be a direct bolt on with no extra modification? Currently I am running factory 20's should I have an issues?
Discussion Starter · #5 ·
Yup its a fully bolt up kit the only thing you have to do is cut your OEM bump stops out in the rear and you can in the front if desired and install the aftermarket EVS bumpstops im supplying with the kit other than that there is no cutting or drilling required and yes the stock 20s will work just great with 55 or 60 series tires I can do U turns like no ones business and it rides better than stock
Discussion Starter · #7 ·
Yup stock shocks front and rear and we have some pretty rough roads out here in northern California and it hasnt bottomed a shock out once in the three months I've had the kit on the truck
Just to confirm , you want to sell the kit that on that truck? also will the bell tech lowering shocks work with that kit?
Discussion Starter · #9 ·
Yea its the kit off this truck shown above because my ram runner project truck is alittle to crazy to use as a work truck so i put a cst 4 inch lift on the sport so i can use it for work cuz 600 pounds in the bed driving down logging roads will not work lowered haha
Discussion Starter · #11 ·
Il tell ya exactly how i did it i cut exactly one coil out of the left front coil and about 2/3rds of an coil out of the right front because for some reason the right side sits about 1/2 inch lower than the left, and then when ya get that 3/4-1 inch lower the truck sits on the bump stops and i cut the stock bump stops and cups out with a 45 degree angle grinder and bolted in Daystar EVS part #KU09041BK and wella you have a lower stance and a great ride
Is this kit still up for grabs? If so send me a personal email, not enough post to PM.
Also and idea shipping to SC??
[email protected]
Thanks
Discussion Starter · #14 ·
Email sent blackedout12 , thanks for the interest
do you still have the kit? I have a 09 Q and want to lower it. waiting on my tax return to credit to my account and would be veruy interested if you stil have it.
Discussion Starter · #16 ·
yup as of now i still have it theres a couple folks on here that want it and a couple people local in northern california but no one has stepped up yet haha everyone wants a good lookn truck but its such a pain in the ass !!
Never got you message in regards to the lowering kit. Been away for a couple of days, let me know if you can resend me an email.
Thanks
Discussion Starter · #18 ·
check your spam box or just call or text my work phone nine one six 663 eight three 88 and we can work something out, its all boxed up and ready to go
Emailed and called a couple of times no response. Is it still for sale??
1 - 20 of 21 Posts
