1 - 2 of 2 Posts
Discussion Starter #1
I recently installed new led low beams and after seeing how well they worked I ordered the high beams and fog lights. Well when I installed the low beams everything was fine. Once I installed the highbeams, everything got thrown up. I dont understand this. So I found the adjustment screw and I got the passenger side to adjust properly. My drivers side will not even get close to where I need to be. Anybody have same problems?
If you don’t have the led bulbs in the proper position in the socket, it won’t throw the light correctly. I have watched and read this online. Go out and look at the bulb and see if the led diodes are facing right and left instead of up and down.
1 - 2 of 2 Posts
