Hi Guys, I just installed an Air Lift WirelessOne on board compressor in my truck to run my Air Lift 1000 bags. I mounted the compressor, manifold, and relay above the spare tire bracket in the back (figured that was the best place to keep it as dry as possible without putting it inside the truck). From there I ran the main power wire up the drivers side of the truck zip tying it to the main wiring harness. My question is does anybody know if there's an unused cell in the fusebox that's turns on/off with the ignition that I can hook the wire up to? If not, where would be my best place to tie in to 12v ignition power?
