1 - 4 of 4 Posts
Hi there,
Went to look at this truck today, guy said one day the wiring harness just lit on fire(looked at it and its just a few wires that are melted. doesnt appear to be the entire harness). Its been sitting at his house since.
Was thinking of going over to you pick it and do some searching. Any ideas would be much appreciated! I really need a truck and I cant afford something newer right now.
can i just bypass the harness and ignition to see if i can get the thing running? run a positive from the battery to the starter? or the external coil?
does anyone on here have the wiring harness within reach . ill buy it from ya!
thanks
rich
Sounds like the voltage regulator went out. And no, you're not gonna bypass that system and get it to run. That's a Magnum.
1 - 4 of 4 Posts
