1 - 2 of 2 Posts
I am having to replace my engine wiring harness due to fire. Junk yard has harness but for 1997 and mine is a 1998 Dodge RAM 1500 Quad Cab 4X4. The first 8 Vin numbers are the same. The only difference is the 10th digit which is the year. The tag on my wiring harness is 18 years old and unreadable. Was there a big difference with the year and will the wiring harness work?
I just helped a friend put a 98 engine into a 97 1500 4x4 and we used the harness that was in the 97 and it worked just fine so you shouldn't have a problem. Good luck.
1 - 2 of 2 Posts
