I do not have the manualGreetings and welcome to the forum. Do you have a repair manual?
Well I removed the calipher to check the bearings but failed to get the hub off so put it back together. After that I would brake and when I got down to about 3 mph the ABS would kick in and seemed dangerous so thought the brakes needed to be bled took it to a brake place they bled the brakes but thought the problem was the speed sensor for the side that I had removed but they were unable to get one so, I took it to Dodge they claimed it was discontinued, and no aftermarket part available. I decided to pull the ABS pump fuse until I can fix it. Since then I put the fuse back and now the ABS light is on all the time. I can't seem to get any progress in fixing only going backwards.How do you know you're having issues with the ABS? Is it just that the light is on on the dash?
4 wheel ABS2 or 4 wheel abs?
Yeah I have those I just can't get the wheel sensorsGuess the guy never heard of Google.
1997 Dodge Ram 1500 Truck 4 Wheel Drive with 4 Wheel ABS Brakes Front Driver Side Wheel Bearing & Hub Assembly TRQ BHA53932
You might think the wheel sensors are in the hubs but there notYeah I have those I just can't get the wheel sensors
Were talking 1997 4x4 ram sport with 5.9 L engine all the web sites say not for my truckYou might think the wheel sensors are in the hubs but there not
So did I but I have ordered exactly what was posted to me but when I received them nope. The wheel sensors are actually part of the assembly that it is mounted to. I don't know what you call that.I thought the link Moparite posted showed the wheel sensors wires came with the hubs? Maybe I missed something?
The sensors on my truck are mounted to the steering knuckle not the hubsThat's messed up- I guess just do more digging till you find correct ones?
O had a 97 4x4 360 eng. Always had a brake problem. Hard to stop it. The problem is in the brake metering system. I believe it had a rear sensor on top of gearbox and one near the brake master cyl. I am a retired dodge mech. Dodge really screwed up rat model and year. The tree is a metering valve coming off master cyl.. that's what I was working on before my Son took the truck.I recently purchased a 1997 Dodge ram 4x4 but I am having problems with the brake ABS system can't find wheel sensors and everything I do seems to get worse
