I recently bought a '98 Ram 1500. Currently, only my rear turn signals work, unless I turn my headlights on, at which point none of my turn signals work; it doesn't even make the clicking sound in the dashboard.
I've already replaced all the bulbs [switched to LEDs] to rule out a bad bulb issue.
Replaced the turn signal flasher relay.
All the fuses are good.
I'm a little iffy about the wiring; it clearly had fog lights and a light bar/some sort of after market lights if the number of wires leading to connectors and/or sockets that aren't connected to anything or empty are anything to go by. Any loose wires, I've taped up the ends on them to make sure they're not touching anything they shouldn't, but I'm thinking one of them may be a ground wire that the ring has broken off of.
Any ideas/advice/diagrams would be totally appreciated.
