1 - 2 of 2 Posts
Discussion Starter #1
My 98 ram 2500 front cab mounts are nearly rotted away along with my floor and rocker/cab corners I'm planning a restore on my truck I found a guy with pas cab mount and I have floor pan out of rock auto along with rocker and cab corner my question is (when I'm putting it all together is just welding new cab mount to floor pan strong enough?)thanks I hope someone out there has done this I know you can't really find cab mounts for these ne more
After welding everything up, you could go inside, wire wheel behind the repair, then fiberglass a nice pad/backing plate about 1/4" thick. I've beefed up and put back together a few Japanese cars. As long as the glassis hidden under rug or floor mat you should not have an issue with state inspection.
1 - 2 of 2 Posts
