1 - 5 of 5 Posts
i see this is your first post, hello and welcome, i am sorry i cant help you but it looks like Remerson228 already has :smileup:
Gauges don't work and odometer flashes
I have the same problem. Changed the cluster, replaced the computer. Nothing. I blew up the tranny and nothing worked after that. Do I need to have the computer reprogrammed? I bought a used one...??
My last car i had a non working cluseter and i put a fuse tester to it, started researching for problems, nothing, eventuletly i desided to pull the fuse, i re tested them all again (yet nothing) but when i pulled the fuse it was shot (not sure y the fuse puller was still reading) so if you havent pull the fuse, other than that the best thing to do is befriend someone who is great with everything your not :-D lol good luck
1 - 5 of 5 Posts
