1 - 4 of 4 Posts
Quick question... So in going through my new truck I found under the seat that Ram included the reducer for the hitch receiver to go from 2.5" down to 2". Anyone know if that changes the limits? I would guess it reduces you to at least class IV limits, but does it have any other effect?
I couldn't find anything on it in the manual.
Premium Member
If i am reading correctly:
https://www.curtmfg.com/part/45408
The reducer, if it is the sleeve type, keeps the hitch weight capacity
if it is a solid welded piece, the towing capacity is lowered
Does NOT change the weight rating of the hitch itself, however, the 2" ball mount is rated lower than the 2.5". That may sound confusing but I am saying the hitch itself has a rating that will not change, but once you use a 2" ball mount you are now limited by THAT particular piece of the equation which are generally rated less than a 2.5" ball mount. Same deal when going from a 2" ball to a 2 5/8" ball. The ball mount is still rated the same but the limiting factor is now the ball.
Wow, I probably really over-explained that one. Sheesh. Bored at work, sorry.
Discussion Starter · #4 ·
Over explained... Eh, maybe.. I would say thoroughly explained. But you answered the question, which may not have been asked well to begin with. A 2" receiver on a 2 5/16 ball that I have is rated at 1000lb tw and 10,000lb gtw. So the reducer retains those limits.
1 - 4 of 4 Posts
