1 - 4 of 4 Posts
I have a 2011 1500 Ram and looking to put 17 inch rims on. The rims are off a 2010. A few questions is the bolt pattern the same? Also wondering if the Air Pressure detection in the message board on the dash will still work?
The bolt pattern is the same so they should mount up no problem. As for the TPMS tire pressure monitoring system) You will need to make sure you take them out or your current rims and put them in the 17's
1 - 4 of 4 Posts
