I have 2001, Dodge ram 1500 5.9 liter. I just moved to Minnesota so the heater is kind of important to get the heater working. I am getting weak heat. my corolla is hotter inside than the dodge. I have been trying to get it to work better. So far I have replaced the hoses and gotten an new heater core (the old one was leaking) I was a dingus and used the oem hose clamps which I didn't get tight enough down so glycol leaked into the cab and left a nice puddle. I had to pull the dash apart to do it. I have done this several times. I checked my anti freeze level and its topped up now. I can feel the heater core when the glove box is out and it gets hot, almost too hot to touch. My heater blend door motor is toast because glycol got into it, so i manually turned it to the open position. I am getting warm but not hot air. Short of taking the heating unit out as well as the dash I am at a loss as to what to do...
But it gets better... Now I am having electrical issues.
Running lights won't turn off (Happened after I pulled the dash out last time)
Hazards come on instead of left blinker, when lights are off, Hazards freeze when running lights and head lights are on (gradually became an issue, would resolve itself now is permanent)
Headlights randomly turn off, only way to get them back on is to flash the high beams.
I am going to try to get a hold of an FCM if this dodge even has one
I thought it might be the blinker arm and the module that is integral to it.
I am so done here. It is getting to the lower 20s here and I am sick of this truck. I have tried other forums and gotten no wheres. PLZ HALP
