1 - 3 of 3 Posts
I have an issue where my passenger window will only roll down if i first try and roll down my driver window. I don't have to hold down the driver window button, i just need to click it once and then the passenger will be able to roll down their window. Has anyone ever ran into something like this?
thats happend to me some times, im thiunk is just some energy cut from the drivers switch, but you can check-test instruments, hold down the stick of the odometer in the dash and turn the key to on position, and one of the codes i get is open circuit open from window swich or somethin, maybe you habe that too
what you need to do is take apart the drivers door switch and you need to resolder the prongs on the window lock button and this will fix your problem this is a common problem
1 - 3 of 3 Posts
