1 - 3 of 3 Posts
Discussion Starter #1
I have 2.5-3 inches of torsion key lift on the front of my 1500 off road package. I added a bit of lift in the back at the shackles as well, all to clear the Goodyear DuraTracs I wanted to run. I use Bilstein 5100s on my '95 2500 and really liked them. They make 4600s front and rear for the 2003 1500 4x4, but only the rear has 5100s listed. I bought shock extensions and kept my worn stock off road shocks for the front and put 5100s on the rear.
However, a person can go to the Bilstein catalog for chassis builders and find shocks spec'd by size. I measured up my stock setup and found the 5100s in a length that would work, but the lower eye/bushing combo would not fit the stock bolts. This was likely the reason no 5100s are spec'd for the torsion bar front suspensions, not enough demand to make a special run with the larger eye required.
My solution was to have my machinist friend turn me some bushing from T6 treated aluminum barstock. I took the front end apart for wheel bearings and ball joints, set my new shocks.
Here are the shocks....
These are the bushings.....
.....and installed..........
I've run these a bit after install, they work very well. I like the 5100s, they made my 3/4 ton feel a lot more sure footed. I run 275/70-18 10 ply DuraTracs on both trucks, a pretty heavy tire I guess, but the shocks handle very well pavement or not. I spend a lot of time off road, not usually just for fun, but our Canadian property is very remote, and work roads in the Permian, at least where I am are absolute s**t, full of craters and busted up. Timken made those bearings, good price, cheaper by far through RockAuto than the Chinese junk NAPA wanted to sell me, but I felt the need to put a bit of vacuum hose on the ABS wire as a shield, as it bends pretty hard around the knuckle. Proforged ball joints, seem pretty solid, we'll see.
Can the ride height adjustment feature be used like this? What are you running in the rear? Solid bushings noisy? Would your buddy make more? Thanks
Discussion Starter #3
Ride adjustment, if I understand you correctly, that is what I used, different torsion keys to lift front.
I used the 5100s Bilstein makes to fit the rear.
No noise that I'm aware of, that inside diameter is pretty snug, but I would check it against the bolts you plan to use.
Making more, I doubt it, he's buried. Here is a sketch I made, you can take to your machinist. Good luck.
1 - 3 of 3 Posts
