1 - 3 of 3 Posts
Discussion Starter #1
I bought this truck a few months ago. All of a sudden the front passenger window wouldn't roll up from the passenger side. It worked from the driver side. Now it doesn't work at all. I have power windows
Welcome to the forumz from Maine. You have to figure out where the problem lies. If you carefully strip the wires back on the pass side door, you can try a 12V positive and negative feed from a 12 volt source (cordless drill battery) If you can make it go up and down, then the problem probably is in the drivers side door switch. I had to replace mine once when I let it get wet from leaving window down, wasn't very expensive.
Good info here
I am having the same issue except with all my windows. They only work from the drivers side. I will test them out from the main switch first
1 - 3 of 3 Posts
