Recently ran into an issue with the rear diff, pinion seal started leaking and whining/hum sound began shortly after. Now its quite loud, replaced rear pinion seal and pinion bearing to see if a quick fix would do it but no luck.
Opened it up and found some chipped gears and way too much backlash play that we couldn't adjust.
9.25 diff, 3.92 gears, everything i am finding is around 750 an axle except Durangos are about 300. Question is, can you directly swap a Durango/dakota or another vehicle axle as long as it is a 9.25 with same gear ratio and wheel bolt pattern?
