No codes, I'm not a mechanic not sure on lean or dry. ThanksHave you gotten any codes?
Barely runs you mean lean or dry?
Any more details
Acted like it running on less cylindersNo codes, I'm not a mechanic not sure on lean or dry. Thanks
No power just enough to keep it movingActed like it running on less cylinders
I took off from a stop and it made a loud noise like a tire blowing out and then I had no powerHave you gotten any codes?
Any more details
What year is it and how many miles? Does it backfire when you give it gas?I took off from a stop and it made a loud noise like a tire blowing out and then I had no power
I hate to say it but sounds like a broken valve spring. When the hemi first came out they had some valve spring issues. Easiest ways to check is with scan tool looking at adaptive. Not having that I would run comp check if you have a low cyl remove that valve cover and check. It can be changed without removing the head2004 - 219,000 miles and yes it will backfire. Thanks
What about the crank case vent tube?If it is sucking air thru the dipstick tube & the oil fill cap I would look at the intake gaskets. Where else could cause vacuum to come from.
