1 - 6 of 6 Posts
Discussion Starter #1
I have a question my 2004 dodge ram has the 5.7 hemi an thee crankshalf position sensor went out on it causing the truck to go into the limp home mode i replaced the sensor with a new aftermarket one still doing same thing cannot clear the po335 code either any suggestions on how to fix this problem thanks in advance
P0335 is crankshaft position sensor. It may be dirty and could be cleaned. It may be the sensor is faulty or the
timing wheel has a problem. Suggest you investigate. Bills86e
Get a Mopar/OEM sensor. Been my experience over the years that with these types of sensors the aftermarket stuff is sh!t and doesn't last.
Always before disconnecting any thing electrical, Remove your Negative Battery Cable. This also will Clear check engine light!
Bills86e
1 - 6 of 6 Posts
