1 - 1 of 1 Posts
I have a 2004 Ram and am having trouble with the Heat and AC fan not working. The AC/Heat does put out cold/hot air but the fan does not come on when truck is running. I believe the problem is in the ignition switch because I can make it work by slightly turning the key switch backwards just a little bit 1/16" or less but comes and goes with vibration. Do I need to change the ignition switch or is there a replace piece that detaches form the ignition switch?
1 - 1 of 1 Posts
