1 - 7 of 7 Posts
2006; 3.7L; 125,000mi
Coil 5 continually blows.
Replaced coil from free used set several times and truck ran great but it would blow again in a day or 2.
Replaced plugs with copper set, gapped .040, new set of coils, new ECU.
This worked for 2 weeks and today it blew again.
Can't remember the codes but it was misfire on #5 and then there were a couple codes relating to the transmission (i do not know how this could be related other than a by-product of misfire).
I have read responses from various places and I have replaced what others have said is the problem but it clearly isn't.
Where do I go from here?
Thanking the community in advance!
@RamTech hoping you can help.
Premium Member
That coil certainly got hot & melted
What spark plugs are you using ?
what year is your truck ?
Discussion Starter #4
2006 with 3.7
It is a Dakota (not a ram)
This is the 6th coil that has blown.
Do you know where I can find a schematic of this? I would like to run wires directly from ECM but the ECM is packed tight and need to find the right wires.
Premium Member
If the spark plug being used burns at a higher rate than stock, it will burn out the coils
The spark plugs that you should be using are
NGK 6987 {#ZFR6F11G} V-Power, Copper plugs
Gap 0.044"; Actual OE Part
$1.67 each
https://www.rockauto.com/en/catalog/dodge,2006,dakota,3.7l+v6,1432508,ignition,spark+plug,7212
The Coil On Plugs seems to be made by
UNITED MOTOR PRODUCTS COP101 United Premium OEM replacement COP coil
$16.87 each
https://www.rockauto.com/en/catalog/dodge,2006,dakota,3.7l+v6,1432508,ignition,ignition+coil,7060
The spark plug & coils are the same for the 2006 Rams with the same size engine
Discussion Starter #6
$1.67 each
$16.87 each
That is exactly the plug and coil. Under the hood the sticker said gap to .040 so I did. 2 plugs needed adjustment but 4 were perfect.
This is not a spark plug issue. The set I replaced were Autolites. 6 coils on cylinder 5 is not plug or coil issue - it is something electrical. Maybe a bad wire which is why one of the things I would like to try is to run new wires from ECM connector to coil (reason for looking for schematic so I know which terminal(s) I am dealing with).
Zero issue with other cylinders and plugs from them look beautiful.
1 - 7 of 7 Posts
