1 - 3 of 3 Posts
Ok, I just picked up a 2006 Dodge Ram 2500 with a HEMI and tried the cruise control switch install and it's does not work. I thought this truck was compatible with the install. Any one know if I'm missing anything? If not will they work on my 2007 Dodge 3500 Cummins 6.7 with manual? ......... :wavey:
Did your truck originally come with cruise control? If not, you may need to get the trick programmed for the cruise control option at the dealer. I installed the aid controls on mine and had to have it programmed. I also had to run a wired from the back of the clock spring to the back of the cluster guages.
Discussion Starter · #3 ·
I put the controls on my 07' 3500 C&C with manual, work like a charm! I just put fog running lights on the 06' and have to have it programmed so I'll have then activate the cruise (if available) at the same time and try it again!
1 - 3 of 3 Posts
