1 - 4 of 4 Posts
So last week my 2007 dodge 1500 lost its third gear. I brought it to the shop and they immediately said the transmission was shot. Luckily I had a buddy with a transmission for me with only 10,000 kms on it. But after putting in the new trans, I’m getting the same result, no third gear. Getting codes P0869, and P0733. I also noticed when I put it in drive and reverse there was a delay before it kicked into gear. I then plugged out the speed sensor on the passenger side of the tranny and with it plugged out I got immediate response into drive and reverse, but still no third gear. Anyone experienced something like this?
P0689 ECM/PCM Power Relay Sense Circ Low
P0733 Gear 3 Incorrect Ratio
Check your wiring to the trans. Also once you work out this proble, don't forget to get a quick learn done, or you may be replacing this one sooner rather than later.
Discussion Starter · #4 ·
The first code is P0869 which means Line Pressure High. But thanks for the reply I really appreciate it! I’ll take any ideas on how to get this thing fixed lol
1 - 4 of 4 Posts
