1 - 1 of 1 Posts
Discussion Starter #1
I've read these forums enough ro be completely terrified of doing any electrical work on this truck. However I'm adding an onboard air system and will use the opportunity to add a set of air horns as well.
My question is can I use the horn power wire to drive the air horn solinoid? When I read up on adding driving lights that splitting off the headlights would cause issues & chose to add a factory switch, harness, & lights to avoid messing with the TIP.
I would prefer to use the horn button instead of having ro run a separate switch/button but will if it will cause issues.
Thanks in advance for any info.
1 - 1 of 1 Posts
