1 - 4 of 4 Posts
I recently had a 6in BDS lift installed on my Ram and noticed that it doesn't sit level. The rear end is almost 2in higher than the front. Is that right?
yup, factory sits higher in rear. if you lift the front 6in and the back 6in it will still remain higher. that way when the bed is loaded it sits level
you could drop to a smaller rear block to level it or use bilstein 5100's in conjuntion with the lift to lift the front up to 3 more inches
1 - 4 of 4 Posts
