Hello, truck sat for a couple weeks while on vacation and a mouse had a good snack on my Injector and coil wires for cylinder 4/coil D. I cut back the loom to expose more wire and there are 3 wires, brown/white stripe! which go to which? I determined 2 were grouped together coming out of the top of the loom to go to the injector and the other solo wire to the coil. The Blue wire for the coil was intact.
Started it up and the code still reads "misfire secondary circuit Coil D." Swapped Coil B to D and the error still reads coil D. So the question is, how do i know which brown/white strip wire goes where?! I'm assuming I wired it right because I do not get a code for the injectors. The coil isn't bad and the loom is untouched so thinking the rest of the wires are intact. New coil connector pigtail?
