1 - 3 of 3 Posts
Discussion Starter #1
Has anyone had issues with there condenser fan not running?
I ve change the relay , changed the temp sensor on the motor
Put power to the fan it runs
Power going to the relay is gone
The fuses are good the wiring harness looks great????
Any ideas
Just replaced mine in my 2005 1500. AC has been running great ever since. Had a problem with the replacement motor though. The fan did not fit on the motor spindle. Had to bore out the hole in the fan to fit properly on the spindle, secured with the hardware provided and it was good to go. Not sure how similar your 2011 is to my 2005, but hope this helps.
Any ideas
Same problem on my ‘12. Fuse good, relay good, can run 12v to fan and it works. Checked voltage at fan connection-no voltage. Removed resistor to check, no corrosion on electrical connections. Going to pull dash panel to check voltage at fan speed switch to track voltage to fan. I have read about ignition switch issue, but don’t know what to check on it.
1 - 3 of 3 Posts
