Hello everybody looking for a little help here if anybody out there can give me some insight as to where to go from here I have a 2012 Dodge Ram 2500 with a 5.7 Hemi lifter failure which led to destroying the cam which course caused the misfire in cylinder number 2 also code showing for multiple misfire replace the camshaft replace the lifters did all gaskets put everything back together now the truck will start up run extremely rough and shut down will stay running if I pedal the throttle at a higher RPM but still runs rough did compression test on all cylinders all showing good put brand new coil packs brand new spark plugs brand new injectors nothing's changed if there's anyone out there that can help please I am almost out of money and this is my only vehicle truck also has brand new battery and misfire codes are still showing up now showing as a permanent code
