1 - 20 of 66 Posts
Hey guys,
Just got my truck back from the shop and would like to share these foto's..
Lift: BDS 6". 5" Fox shocks in the rear.
Bilsteins in the front are set halfways
Dual steering stabilizer
Rims & Tires: Rockstars 20x10
Toyo Open Countries MT 37x13.5x20
I dont have any rubbing at all and have about a 1/2" of space between the tire and upper arm control.
Measurements for the center of hub to fender.
Front: 27.5 Inches
Rear: 28.5 Inches
Before the lift:
When she was clean:
From the Side:
Tire:
Front Axle:
I asked bc 1.8" isnt a setting genius :D
My driver side looks like that too. The bottom of my coils are 180 degrees out from each other on the driver and passenger side.
Discussion Starter · #8 ·
Thanks guys!
I'm 100% satified with how it came out and rides.
The Fox shocks are a very smooth ride, as you can see I travel lots on the gravel roads.
The bilsteins are only set halfway, but once they settle ill raise them some more if nessasary.
Looks bad ass OP!
Anytime you lift a truck and put 37's on it you will notice a power loss. I noticed a little but after my tuner I have it right back. When you set your tire size it helps BIG time!! Then when you add the tuner for more power its another WOW!! So when the tuners come out for the 11's and 12's its a must to have. You can go ahead and buy a tuner for the tire size and gear ratio if you change gears. then when the tuner comes out for the truck you could up date the tuner.
1 - 20 of 66 Posts
