1 - 11 of 11 Posts
Hello Everyone
Can someone direct me to the Chrysler/Dodge/Ram complaints department please? Maybe the C.E.O.'s home phone number would be helpful.
2013 Ram 1500, 8 speed 3.6L, 65,000km NO Start. I've owned it since 58,000km.
Just had a new starter installed on Saturday after having the truck towed to the dealer. Truck ran for 3 days in a row!
Lots of electrical errors:
check engine,
service 4wd,
service shifter
are the three main trouble errors over the last 2 weeks.
Any suggestions?
Dan
Premium Member
2013 RAM Laramie Crew Cab
Contact RAM cares on the forum they should be able to help with your problem
Discussion Starter · #6 ·
Update
The truck has been running for 4 days now!!!
Initial codes were
P0622
P1915
P1B13
U1465
U1466
U1467
Those codes were cleared and parts were 'flashed (?)'
A new starter motor was installed.
A few days later; a ground cable was found to be loose. It was cleaned and a new hole was drilled for the ground.
A few days later; a second ground cable (redundant) was installed. It seems that the Dealership only called for Dodge Tech Support after my truck was towed-in the 5th time.
$1400.
Looks like I got off cheap. I basically had the exact same issue. The tech at my local dealership was able to spot the bad ground, but only after installing a new starter. Luckily the codes were still happening after the install so they knew to keep looking. Today is also day 4 for me with no issues. I am thinking about doing a big three grounding kit. Hopefully that will help prevent these kind of issues.
Are these issues popping up with the 3.6
Good question, I haven't seen anyone else besides myself and Dan having this problem but it seems like a pretty big coincidence. Also, my truck was bought used and actually came from Canada. I noticed Dan is in Ontario. I am wondering if there was a batch that had bad grounds. The issue definitely took a while to present itself. My truck now has 45k miles on it. I would say anyone having weird electrical issues should have their grounds checked first. It's an easy fix when it's diagnosed properly.
Hello Everyone
check engine,
service 4wd,
service shifter
Any suggestions?
Dan
I have this same truck I have electrical problem starting from Fuel pump relay dash board outlets stopped working, radio comes on by itself. Truck lifters replaced twice at 75,000 and 130,000 I’m a female I didn’t drive the truck hard or carry large loads and oil change never late.
1 - 11 of 11 Posts
