1 - 10 of 10 Posts
I have a 2013 1500 Tradesman 4X4 3.6 V6 8 speed transmission, for some reason 4 wheel drive high was never installed and would like to fix that. Any ideas ?
Super Moderator
What do you mean it was never installed? A 2013 Tradesman has the Borg-Warner 44-45 transfer case and that most certainly has a high range. Is it just not shifting into it?
Discussion Starter · #3 ·
I would post a pic of the buttons on the dashboard but we seem not to be able to here. I only have 3 buttons on the selector, 2WD, 4WD Lock and 4WD Low.
Super Moderator
4 lock is 4 high. The switch you don't have is 4 auto, your transfer case is the part time one which doesn't have auto
Discussion Starter · #5 ·
Hmmm strange, I'm used to 4 high (25mph and above), 4 low (below 25) and 4 wheel lock that locks everything up and should only be used in 4 low.
4Hi and 4Lo both force the front and rear drive shafts to spin in unison. 4Lo adds additional gearing reduction.
I'm a little confussled. Which vehicle had those options? You may be referring to differential locks, which force both tires on the axle to spin in unison.
Discussion Starter · #7 ·
4 high and low engage both axles but allow slip, 4 wheel lock, locks all 4 wheels in with no slip. It least that's what I always understood.
Discussion Starter · #8 ·
I had a Jeep Cherokee Trailhawk that had all 4, 2 wheel, 4 wheel low, 4 wheel high and 4 wheel lock. You did not want to put it in 4 wheel lock unless it was in 4 wheel low, in fact it wouldn't let you.
Super Moderator
"Lock" is referring to the transfer case locking the driveshafts together, not the differentials. There are no locking differentials on Ram 1500s, your front is open and your rear is either a limited slip or open.
On these trucks 4 lock is the high range. There is also 4 auto if you have the 44-44 case and allows you to drive on dry pavement just fine. That's a clutched case though, yours doesn't allow for slippage between the driveshafts when 4 lock or 4 low is engaged
Discussion Starter · #10 ·
Ok got it. Thanks.
1 - 10 of 10 Posts
