2013 Ram is now online ?
3321 Views 7 Replies 7 Participants Last post by  luckymckay21
http://www.ramtrucks.com/en/2013/ram_1500/
you can't order it yet, you will likely have to wait for the first week of July to do that
at least you can sign up for email for more information as it becomes available
1 - 8 of 8 Posts
Very nice.
Is it true they won't be available until the end of '12?
That ram is sexy, no shifter? Just a knob.
Did we lose the slap shift on these 2013s?
from what i can see on the pictures, it will be on the streering wheel
The knob with the shift buttons in the steering wheel only apply to the 8spd trans. If you opt for the 6spd, the controls are either a column sifter of console shifter like before. :)
The HEMI with the 8 speed ZF transmission will not be available until at least January 2013
The V6 with the 8 speed will or should be available to order in July, for delivery in late August 2012
Well i guess opinions vary, But i will be sticking to my 2011 Sport.
I recently had a 2012 Hemi as a rental and and was not impressed at all with the 6 speed. and the 2013 Interior to me is just more that can go wrong that we can not fix are selves
The 2012 6 speed is the exact same transmission as the 2011 5 speed if I'm not mistaken. The only difference is a different torque converter and new programming that allows you to manually select the 2nd gear prime kickdown. Still drives and shifts the exact same as the 2011 when simply put into drive.
1 - 8 of 8 Posts
